What steel do you use to make gears from? I need to make a small 20 tooth gear and don't have a clue as to what to make if from. It is for the fine feed option on my heavy 10. I made one from brass but it is showing some wear. I expected that as it is a brass gear driving the steel gear on the banjo. 12L14 would be easy to machine but I don't know it it can be hardened or not. Opinions please.
