- Jun 7, 2013
- 10,142
Anything that I have ever seen or read, stresses that to avoid thermal shock, work to be heat treated should always go into a cold furnace and come up to temperature gradually; that is the way I have always done it.Thanks Flammable. Sounds like I better stay away from the door. Just out of curiosity, say I was heat treating a 1-2-3 block. Would there be any good reason to put the block in the furnace at ambient temperature, then ramp the temp up to the set point, let it soak, then remove it? I.E. does the work HAVE to go into a hot furnace, or can it go in a cold furnace and heat up as the furnace does? Thanks.
Bob
