It's been several months, and I have just about completed the project, but thought I'd go ahead and share some photos as I close in on the completion. I have enjoyed the work, but I can safely state that she will be my last, given the time and cost of such work. Let's get started...
She sure looked better in the pictures than in person, but we'll take care of that...(pics here are better than she was, honestly)
Thanks shipping company...
More fun times ahead...
Red, reall? Man, that should be illegal...
That motor will have to go...
That's just not going to cut if for me...
Here we go...More coats than an Eskimo
She's pretty under there...(stainless can be eaten by rust, but I stopped the cancer in its tracks by getting down to the metal)
The rust was pretty well socked in there...
Dang thing was warped, but I managed to remove and square the gears...
Sanded, and filled, sanded again, primed, then painted. I wanted this piece to be far prettier than it should be--I'll be looking at it often...
Painting time...
Industrial Primer, two coats, then paint...
Rust under the label, of all places. I replaced this with a laminated version that looks incredible, and it is a scanned copy of the original. No more muss or fuss...
Cleaned oilers, new tape and wicks...
Made controller box for VFD from a solid block of 6061 Aluminum using my CNC machine...
I have not mounted it yet, as I have been unable to determine exactly where I want it.
I created a support plate to mount the Variable Frequency Drive (VFD) and resistor, then machined it and clear-coated it to prevent oxidizing...
As you can see, it required a lot of drilling and measuring, but the result is very impressive; I can take the panel down as needed for servicing...
You can also see the upgraded 1 HP motor, and the brake resistor to the right. I also took the opportunity to mount an auxillary power outlet for lighting and
anything I cannot anticipate at this moment.
Flash fuses and switching for a power cut-off switch that'll will allow me to control power to the motor.
I slaved the external power box for other ancillary accessories off the main power block.
I sanded the doors down to the metal, and like them so much that I decided to leave them that way, with a mish-mash design and clear-coat...I'm not happy with one door,
so I'll be reclear-coating it. One has more mirror finish than the other--just the way I am. I'll also be clear coat protecting them with 5mm clear chemical resistant silicone--the entire doors. So any spills or kicks or scuffs will not harm the finish. It's the same stuff they use on sports cars to protect them from gravel etc.
It seemed appropriate to polish the plugs as well--adds a nice touch in my opinion...
Replaced the crappy door plugs as well to be sure when the door is closed, there is no rattle, and there isn't. Love the look of new on old...
The old plaques were unacceptable, and unreadable. So in with the new...
What a difference that makes...
I added a pull-push switch between power and the VFD. But it was a little nasty so I cleaned it up...
New Three Phase Motor to run off the VFD...
Liquid and checmical reistant plug. I kept it short so it doesn't bang against my lathe or its panels. My power comes from above so it works great.
I also added cabinet door triggered cabinet lighting. I hate not being able to see what is in there when I'm looking for a tool...
I also placed anohter light over the VFD box, near the belts and other electrical--I can never have to much light...
I mounted four heavy duty caster/foot wheels so the machine can be moved when needed, and I have already used them several times and absolutely love them. I can lower the feet to support the machine completely. The capacity is 2 tons. I understand some have had issues with wheels, so I am hoping the feet can provide the stability I need. THus far, no problems at all. Very pleased, but not cheap.
I have a massive amount of pictures detailing the process, I chose to keep it to an album, and not a novel. I plan to add more, and a video of the machine in use soon. The whole unit pics to come soon...Cheers~
Painting time...
