- Apr 30, 2012
- 1,138
Yes, I then cut a .040 to .050 slot in the channel to locate the keys then tack welded the ends. Glad to hear your moving along with the build. I put this on another post you might get some use out of it http://www.americanmachinetools.com/pressure_table.htm . I don't know where you are located but if youre close shoot me a pm my shops always open since I'm retired.Hey Piney,
On the slot for the 3/8" key in the base, did you mill the whole .375 depth? Just curious now that I have milled .1875 in the base thinking of the old regular key slot thinking, but soon realizing the channel isn't thick enough to mill .01875 for the other half as it is only .1875 thick. :lmao: Probably easiest to mill the .375 instead of messing with the key stock later on the attachments but I thought I would ask just in case. My base is 1.00 thick by 4.00 wide.
Thanks,
schemer
