Thanks for the suggestion Kernbigo. My only concern about turning the OD is that the replacement shaft is already .001 under the original. If I take off more, then my pulleys might be pretty
sloppy, even with green loctite. I don't have an adjustable reamer of the correct size, but I do know a local machinist that does little jobs like that for me cheaply. If I need to ream it, I'll probably
just have him do it. If I can use a boring bar, I'll do it on the Atlas. I think before I do anything
I'll press the pulley off the old shaft and see how it fits to the new one.
