- Jan 25, 2015
- 2,558
I have to make a tool to change jets in my bike's carburetors.
The "head" is a 6 mm round slotted deal. Like so:
You can't use a normal screwdriver on them as the slot has square edges and a regular common tends ot slip and mar them up.
Normally, I'd just use a tool like this:
It centers the jets and applies the force in the proper place. But my bike has downdraft carbs with small side mounted float bowls. This means the plug over the jet area is very small. Just large enough to extract the jet, no room to fit a tool like above in there.
The other option is removing the carbs and bowls to change the jets. As you have to drop the engine to get the carbs out of my bike, that's obviously not an attractive option.
So I'm looking to machine a tool that will fit the slot in the jet and fit in through the bowl plug hole. BAsically a square sided screwdriver bit arrangement.
My question is: is aluminum a suitable material to make this tool for a brass jet out of?
I don't want it to be too soft, but I'm not keen on using steel either. It doesn't have to stand up to a lot of use, just a couple rounds of jet removal/installation with I get the mixture right. Very little torque/force on a jet also.
Aluminum is also attractive to me as it's easy for me to machine with my limited capabilities (milling attachment on the lathe).
Thoughts?
Thoughts?
