I needed a piece of PVC plate 3/4" thick to make the filter holder in my filter unit. This requires a ring 6" diameter with a 4" hole. I priced the PVC plate on line and the cheapest I could find was in excess of $60 with shipping. This, I cannot afford, so........
I cut some pieces of the 6" pipe off, split them in half.
Then I put them in the oven at 250 degrees until they relaxed and flattened out. I then put them on the counter and set a heavy weight on them to hold them flat while they cooled. I now had some 1/4" thick plates.
I coated them with PVC cement and clamped them together. They bonded into a solid sheet 3/4" thick and I didn't have to spend a dime.
I next cut a 3" hole with a hole saw in the center and sawed a circle out of the sheet.
I will put it in the lathe and machine the finished part and glue it into the filter unit.
More to come....
Mark
More to come....
Mark
