Erl-1340
And finally, it's here. Some shots from the delivery process:
IMG_20160401_123028.jpg IMG_20160401_124009.jpg IMG_20160401_125308.jpg IMG_20160401_125648.jpg IMG_20160401_125709.jpg IMG_20160401_130117.jpg IMG_20160401_170722.jpg
Been going at the shipping grease with Wypalls and WD-40. Got the bulk of it off, but still a bunch of the back of some of the shafts and on the underside of the ways.
So you had the lathe drop-shipped to a rigger? Pretty impressive hoist on that rig. :)
What's the weight on that lathe? Looking forward to you getting it operational and hearing your impressions of that bad boy.
congrats. How much did the rigger charge?
Not worth messing around with something that expensive that weighs 3000#.
Weight's about one ton.
Shipping it directly to the rigger was the easiest way to handle it, especially since it's too heavy for a lift gate and the shipping company only had a rough delivery date. Total charge for the rigger was $600, pretty fair for unloading it off the truck, hauling it from Mt Vernon to Renton, and placing it in the garage.
Sent from my Nexus 6 using Tapatalk
Dang am I drooling. But I totally agree. When you have that kind of money invested into a machine that size $600 seems cheap to ensure it gets placed in one piece and not several busted pieces for less $$. I sure hope you post some youtube videos of that baby in action. I'd love to see it and hear your impression of it. :) GRATZ!!!
Started pulling out the contactors for the VFD conversion. The Hitachi is a wee bit too big to fit in the electrical cabinet, and the front panel lacks enough room for adding a key switch, jog direection, and speed pot, so I bought a Bud NEMA 4 enclosure from Amazon to house everything.
Plan is to put a frequency meter, key switch, e-stop, jog button, jog direction switch, indicator lamp, coolant switch, and speed pot on the front of the added cabinet, and keep the existing front panel controls wired in series (e-stop) or parallel (jog button, coolant switch) as appropriate.
A few pics of the cabinet and stuff removed:
IMG_20160416_155151.jpg IMG_20160416_163237.jpg IMG_20160417_173617.jpgIMG_20160417_173555.jpg
I have built control box extensions for the cover panel when the VFD did not fit. I had some phenolic impregnated CE board that I used, but just about anything will work. Probably want to extend it to around 8". You could probably dump the big transformer for a more compact 24VDC unit if you choose to go that route and plan to use smaller control relays. Surprised you do not have enough room on the front panel, did a recent build on a 1440 lathe, and was able to fit everything in, but the speed readout was put up above under the DRO. I like thisposition, as it is easily seen when operating the machine. You can combine functions, so the power on light can be in the E-Stop or use a lighted Jog.Have been using a joystick for individuals that want forward/reverse jog feature.
One awesome machine, will be a monster once you add the VFD. A perfect combination.
The front panel is constrained by the casting—you can't add anything on the sides because the gap in the casting is about five inches narrower than the panel.
The transformer also runs the coolant pump (1ph 120VAC). I considered connecting that directly to the mains, but decided that the isolation provided by the xfmr was a desirable safety feature.
Getting the cabinet extension for the vfd set up. There's nuts on the back side of the mounting panel—I'm mulling over the option of tack welding then to the panel to make it easier to unmount/remount things. I don't think solder or epoxy would work very well. Another option would be to put the screw heads in back and add an extra nut to hold the screws in permanently.
Top Bottom
