- Dec 20, 2012
- 9,422
Doug, if the hole simply needs to be enlarged I throw a drill blank the size of the existing hole in the chuck and move the X-Y table around until if slips in without contact. This will get you close enough for rough work.
If you need more precision then the easiest way is with a coaxial indicator if you have one. Using a center finder or even a wiggler will also work but it is more operator-dependent as far as how accurate it is. You can also use toolmaker's buttons or even a ground dowel pin; these have tips of a known size and when combined with a center finder you can get very close.
As to whether to use a drill bit or not, it depends on the fit you need. If all you need is a through hole then a drill bit will do. If you need closer tolerances or a finer finish then a reamer or boring head is called for. This is especially true if you need to have the hole on-size AND straight.
