Hi; cutting your own gear. Is a good project even if buying them is cheaper. Look around and see what is available in your area sometime at scrapyard there some old equipment that there would be a rack you can use. The rack are not expensive to buy . I would use around a 16 DP size it seem this would work good for your project. As soon you have the rack then you can plan on building the gear.
