- Feb 2, 2013
- 3,646
VIS Poland is excellent made toolsAnyone know anything about the VIS made in Poland?
as a side note, arguably they produced some of the finest pistols and rifles during the WW2 era, even while under occupation
Someone mentioned that to me but the shank of the bullet isn't the same diameter the whole to the base as there is a pressure ring that is slightly larger right at the base. So I'm not sure if that would work ?I also wonder if a surface comparator with a tenths indicator might work. One of those things that's basically a mini surface plate with an indicator holder sticking out of it. It would probably be fiddly as compared to an indicating mic, but it might also be cheaper.
