- Dec 8, 2013
- 2,651
I can't see the spreadsheet. However:
The radii of the balls to the line of contact form a right angles with the wall of the cone: that it your right angle (not the angle at the ball center). The triangle formed by the radius of the larger ball to the line of contact, a line along the cone to the line of contact of the smaller ball, and a line from the line of contact of the smaller ball to the radius of the larger ball parallel to the center line is similar to the triangle formed by the center line, the radius of the larger ball, and the cone wall. The hypotenuse of this little triangle is the center to center distance of the balls because the aforementioned radii are parallel. The short side of this triangle is the difference in radii. Therefor the half-angle is the arcsine of the difference in radii divided by the center to center distance.
I'll upload a drawing later.
