O
ome
Forum Guest
Register Today
Hi,While waiting for the bellows material I drilled a hole in the casting for a drain plug. SUPRIZE!!!! The main gear box is aluminum. Easy to drill, will add teflon tape to 1/8th" pipe to keep leakage down. Pipe,collar and bull plug to finish.......This machine had no roller on the overarm so today while at the play house I build one with a bearing and some brass pressed on the outside to save the file teeth. Yep, I forgot the pics.....Tomorrow.......I promise.
I have not started on my filer yet, getting all I need to do the job. I am a newbie, so I was wondering exactly what will plug a hole for oil change so it does not leak. Just an oil plug with teflon tape?
What is a collar?
what is the nipple used fof and what is its part description so it can be ordered.
I am not sure whether to use brass or 932 bronze, 1/2" round or 3/4 in round. How long will you make the roller.
I have a round disc On top of bellows area, square steel at top, and i do not know yet what is covered by felt. Hoping bottom piece to fit bellows on is still there.
Do you have pics of filer with no bellows to show how both ends of bellows were fitted on?
Thanks,
Jon
