- Jun 17, 2018
- 15
Hey guys,
I recently completed a "one-shot" oiler system install on my PM30 Bench Top Mill.
Decided to go with Bijur metering valves, junction blocks, 4mm nylon and brass tubing, and other misc 4mm (5/32") fittings.
However, I opted not to purchase the Bijur "one-shot" oiler, instead, I found a "similar" unit on Amazon for a lot less $$$$!
Here are some pics ...
Adding a "one-shot" oiler system to my PM1340GT's quick-change gear box, is in the "works" !!!
I plan to incorporate the Bijur components as well ...
Some links for items purchased...
Bijur components:
One-Shot Oiler (Note: The 'HP-5R' model is "left-hand", the 'HP-5L' model is "right-hand"):
Ball oiler replacement fittings (had to machine some threaded brass inserts, to replace the ball oilers)...
4mm (5/32") Brass tube bender (worked out pretty well)...
Bijur components:
Buy Lubrication System Parts Online | Pumps, Meters & More!
www.fluidlinesystems.net
HP-5R Manual Lubricating Oil Pump 650CC 4mm Right Hand Operated Lubrication Oiler for CNC Punching Lathe Cutting Milling Machine: Amazon.com: Industrial & Scientific
www.amazon.com
McMaster-Carr
McMaster-Carr is the complete source for your plant with over 595,000 products. 98% of products ordered ship from stock and deliver same or next day.
www.mcmaster.com
Amazon.com: Du-Bro 786 5/32" Tubing Bender: Toys & Games
Buy Du-Bro 786 5/32" Tubing Bender: Rebar Cutters & Benders - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
