- Dec 17, 2012
- 630
View attachment Rotary-Broach-Hole-Prep-Speeds-Feeds.pdfHere is from their site.
Great work David, I'm very impressed. Even though you said the wrench fit in nicely, I'm pretty sure you can use a smaller pilot hole diameter than the recommended 3% if you want to . The trade off is faster tool wear and increased pressure, but sometimes a better 'looking' hex. They key is never to go below the flat-to-flat dimension so that you always have separate chips. Beautiful.
- - - Updated - - -
Markknx, if you make your own take a look at the picture of the broach above. You can just barely see the rake angle ground into the face of the broach. The rake angle is critical for getting the chip to start curling up when rotary broaching. I'm sure it would help if you have a way to machine it. Hope that helps.
