- Jun 23, 2011
- 120
I want to make an ER32 collet chuck for my Logan 922, but I'm pretty scared of threading 2 1/4 - 8 TPI into a blind hole when I cut the spindle threads into it.
I'd really like to run the lathe in reverse so I can cut the threads going out instead if in, but I've read horror stories of chucks unscrewing themselves. If I go easy on it and make sure my chuck is tight, do I need to worry about it?
If I DO need to worry about it, could I get around the problem by making a thin jam nut to put behind the chuck? I figure if I screw the jam nut in behind the chuck and then lock it and the chuck together really well, I might get by for one job.
Anyone tried this before?
This will be literally the second time I've tried cutting threads on a lathe. Third if I end up making a jam nut. The first try went very well, but it was an outside thread with good clearance and much slower feed.
