- Dec 1, 2010
- 1,172
And it means looking up the correct torque for the size and material of that bolt, and just as important, whether it's lubricated or not.
Dry threads require a lower torque than lubricated ones.
M
Torque figures for the fastener size, and grade, yes.
(Dry threads require a lower torque than lubricated ones) Im not so sure about that. A dry thread tends to have more friction, and will also tend to give a reduced clamping force when torqued to a given figure.
When trying to get the best torque figure, the threads should be lubed, and also the head of the fastener that it seats to. Both will be areas that friction will affect the clamping force. For a bolt that calls for X-amount of torque, lets just say ft/pounds for example, will have a higher clamping force if, the threads, and under side of the heads are lubed. Dry will create friction, and reduced clamping force.
Over the yrs, Ive torqued down many sets of hi-buck connecting rods. The manufactures also called for one torque value, and they also called for the bolts be lubed with moly based lubricant, or if dry will have a reduced clamping force. The idea in torqueing your fasteners is to get the proper clamping force, and any friction causes error. Such as dry, burred threads, or rust in the thread hole, they all play a factor.
The only other way Ive torqued con rod fasteners is the stretch method. This method you Mic the bolt, and start increasing torque to get the manufactures stretch value. But thats a completely different topic all together.
