- Jun 7, 2013
- 10,131
First, you need to figure if the gears that you have are diametral pitch ( imperial measurement) or module (metric), then you need to figure out the pitch and whether or not the gears are 14 1/2 degree pressure angle or 20 degree P.A. If your machine is made offshore it is likely that they are Module system. The OD of a gear is figured (in the case of D.P.) gears by the formula: N(number of teeth) +2 divided by D.P. = OD, The formula for Module is similar, but different. Your biggest challenge will be figuring out the D.P. or Module; for DP there are charts in the handbooks with profiles if the different pitches, Module may be harder to find --- But, if you were to give the OD of the 66 tooth gear and also the Root diameter of it, the Module could be deduced, otherwise you may look for a set of plastic templates of Module gear teeth and figure it that way, once you find the module, its all simple formulas.
