- Feb 1, 2015
- 9,645
I have measured the gears on the lathe and I used it for reference for the change gears I want to make and it looks like the module are M2.0 if I use the information the members gave me. That being said, I can say this is a metric lathe so it makes sense that the gears would be Module and not DP. In the pic below it shows the gear configuration on the lathe as it is now.
Now that I have the module,I will be able to work out the rest. If someone thinks I am missing something, please let me know, but I think I am ons the right course now.
As benmychree said above, you will need to know the pressure angle. It will be either 14.5º or 20º. This can be rather tricky. The best way is to compare the tooth profile to a known P.A. There are sources online with images which should aid with that.
