- Sep 22, 2010
- 7,223
Guys,
You CAN'T move a Van Norman #12 base (weighs about 400-500 pounds and is bulky) into your basement when you have an angular staircase with bends at the top and bottom.
The stairs won't support it. You will get killed.
But, a thick-headed Ukrainian-Irishman can't be told this.
First off- NEVER, EVER, EVER do this unless your wife is AWAY for the weekend (which she was this weekend). There are two things a woman NEVER wants in her kitchen, one is a Van Norman #12 base, and the other is an engine crane. Second, make sure you clean up good and fix any paint or plaster you damage.
Ok, here goes:
Engine crane set up:
Come-along holdback setup- 2 4x4's against doorway and adjacent wall
Making its way down the 2x12 ramp (secure the ramp together with a 2x4 at the top and one at the bottom as a stop. Cribbing at bottom keeps it in place)
Down at the bottom on the stop.
Cribbing keeps the ramp in place
Engine crane disassembled and ready to go down into basement to set up base.
Moving down from steps and into machine shop area
Machine base in place in shop area
Ok, here goes:
