Welding table
Charles scozzari
Jan 28, 2022
858
Hi, would like to show you my welding table that I made with adjustable/leveling legs. I reworked some trailer tongue stands and inserted them into the 3x3 legs to allow the level of the table or if on an uneven surface take the wobble out. I also mounted a receiver for my vise and grinder with full 360 swing with locking capability. The draw is from a rolling tool cart, and I added outlets to the table The table is 30"x 48 x 3/8" with a 3/8" top. The table extends to a full 8'. The extensions are fully adjustable to maintain a level surface across the span. I also can spin the vise around after removing the handle and hold material over the table using the vise. 5E1DB171-57EB-4F22-8F02-BE7FBECB5381.jpegThanks for looking.6B71BF54-1912-483F-9F81-7A46F58E60A8.jpeg3936CD0C-02F3-48DD-8A8B-3A442D019E26.jpegF89D6116-C8A4-40FA-B62B-46A305625297.jpegEBEF4707-5F00-4CF0-8ED9-71D424B739BC.jpegE2CA2E5A-3DAB-4AB3-9592-30A2C1E489D4.jpegEA592CF0-5269-4AB3-B7C2-F9555241C956.jpegACD9DAD5-F32D-4A76-BCE9-6764C08EB615.jpegEA592CF0-5269-4AB3-B7C2-F9555241C956.jpeg7C10C7E4-486A-4A26-8276-CC58B14C27C7.jpegE4F6CC8C-F3C6-44D1-806A-7D3EA257F2DD.jpeg
So nice and clean almost hate to get welding spatter on it. Maybe some anti spatter spray.
Now you just have to determine your hole size and pattern When you drill the holes beg borrow or steal a mag drill with the appropriate annular cutter.
Hi, thanks for the like. I really am not a fan of the tables with the holes on a small width table like mine. It's usually possible to reach in with deep Vise-Grips for clamping. Plus I prefer the flat table because the holed tables can become blocked with hot slag balls. It's easier to clean a flat surface. Thanks again for the "LIKE".
Nice job and great design. Makes my welding look like chewing gum and duct tape. ;)
I really don't think so, and thank you for the "LIKE"
That's a nice table! I really like the extention.
Thank's very much for the "LIKE" The extensions have made for much easier welding jobs for odd shaped work. Thanks again.
Nice table. There is a lot to be said for solid topped table. If you need to tack a work piece to it, no problem. Just cut it loose and flap disc it smooth when your done. Like the extension too. Mike
Just for fun Tim Young, want to thank you for your "LIKE"
I agree, that's what's nice with the flat table. If It was a commercial cast iron 6' x 12' egg crate table that's a different story. Thanks,
