I turned a piece of torch cut plate on my 9" SBL many years ago. It was around 8-1/2" OD soild! Had to take a side grinder to the OD of the plate to tame down the torch cut a little. It was slow cutting using the back gears.
The way I held the plate in the chuck was. I drilled and tapped four 3/8" holes at 90 deg apart on about a 6" bolt circle. I installed some short socket head cap screws and tighten so the heads were sticking out on the face of the plate. Next, I turned the jaws around on the 4-jaw chuck and clamped on the heads of the cap screws. Lined it up and started cutting. When I finished one side, flipped the socket head screws from one side to the other side. Continued machining. Worked out like a charm!
