- Apr 24, 2013
- 709
Blanks made for the connecting rods. As seen on the top bland the cap has been cut and re-attached in preparation for drill and ream for the large end of the rod.
Large and small ends drilled and reamed.
Centre drilling the small end for the tailstock centre. They will also function as oil holes for the small end.
Thinning down the blanks prior to turning the shafts.
Turning down the shafts.
Connecting rods fitted to the crank and to the pins in the cross heads.
