- Apr 16, 2019
- 745
I wanted to try boring a cylinder knowing that it probably wouldn’t clean up the damage completely . The bore is about 2.650” and 4.5 + long . I had an old axle from a Power King tractor , learned the hard way it was case harden , I broke a tap off in a hole close to the edge . The holder is 4140 I found at the scrape yard . A “ V” was machined at the spindle center line so different size bars could be made to use the same holder . A 3/4” bolt and matching T slot made for the compound . The bolt was used to get the job done but since a shorter stud was installed
