[4]
1/4 in shank or 5/16 th shank lathe tools ?
[3]
[10] Like what you see?
TQA222
Active Member
Oct 29, 2018
69
These will be used on a 7 x 12 mini lathe with the stock tool post. The tool post limits me to 5/16th max in tool shank size.
Is there any benefit with going for 1/4 in shank tools with packing or should I stick with 5/16th ? Or is there little difference.
Light hobby use only, no production runs.
benmychree
John York
Jun 7, 2013
3,241
Unless you need to hang the tool way out of the holder, there is no good reason to use 5/16" tools, added rigidity with long projections is the only reason that I could see, and the 1/4" bits are going to be easier to grind and cheaper.
JimDawson
Global Moderator
Staff member
H-M Platinum Supporter ($50)
Feb 8, 2014
7,668
The 5/16 tool is a bit stronger than the 1/4 inch so should flex less and may improve the finish. Having said that, I use anywhere from 1/8 to 5/8 tool bits on my lathe depending on the exact project and tool requirement for the specific operation. But in general will go with the larger tool bit where possible.
machPete99
Active Member
Dec 12, 2016
129
5/16 seemed to be the correct size for my lathe, as just needed a little shim (maybe .010") to get on center. Thats with the 4-way turret tool post.
Low tech
Jan 21, 2016
24
My 11” Logan came with Armstrong tool holders for 1/4 “ bits . I use These bits almost exclusively. I changed to an Aloris axa tool post and still use the 1/4 “ bits .
mikey
Dec 20, 2012
5,318
The 5/16" bits are not nearly as popular as the 1/4" ones. I've seen really good ones sit on ebay , making it easier to find high quality bits for cheap. They don't take much time to grind and will give you greater stiffness and reduced resonance so I would go for the larger bits, too.
[6]
[5] [7]
