10 inch Disk?
Dgrose
Feb 3, 2020
18
How do I make a 10 inch disk from 3/8" plate? I can cut with plasma cutter but how do I get the edges trimmed? I have a 10 inch rotary table but how do I clamp it to the table and mill the edge? I have a big enough lathe but you can't hold it and cut the edge? How do I make this disk round by milling the edge?
Will your plate have and holes when finished ? Could drill and bolt something to the bottom or right through.If your rotary table has a 3 jaw chuck you could tack weld a round slug under it then grind the welds off . I’m sure there are other ways
I was just thinking, If your rotary table is big enough or a sub plate you could just put clamps around the outside and remove the clamps as needed as you rotate the table , putting it back after cutting where the clamp was .
Place equal height spacers under plate to support it to allow gripping on the lower 1/8 inch of the plate leaving 1/4 inch above jaws.
Cut to size.
Flip over and finish.
Did this in lathe with a thick round foud at scrap yard
On ours we had pocket on one side so cut that an held by it for finish cut.
Sent from my SM-G781V using Tapatalk
I'd probably try CA to put a smaller disk on it to clamp in the 3-jaw, and add a pressure plate with the tailstock.
That's what I would do.
I have used this quite a few times. I would not trust the glue alone, so a pressure plate is good insurance.
BTW if you do flame or plasma cut, give yourself extra space, then sand/grind the edge.. remove the flame or heated edge. I went through quite a few carbide cutters .. you need to get under the flame cut.. mine was an interrupted flame cut because it was done by hand. On the second one I wised up and ground it off before turning it.
Sure you can . Use a pressure pad up against your 3 jaw chuck . :)
This is what I would do. You could even use some super glue for some extra grip.
Joe Pie has an excellent video on pressure turning.
How accurately round does it need to be ?
0.100 almost any reasonable method, including griding by hand, and measuring with tape
0.010 slap the sucked on a rotary table and use an end mill (keep at least 2 clamps on at all times.)
0.001 sliver solder to blank than can be held in lathe chuck
0.000,1 Out of my knowledge base level.
