My new plasma cutter offers a choice of inputs; 110v @ 20a and 220v @ 20a.
The generator I will use has receptacles for both 120v and 240v, each 30 amp outputs.
I run my dc inverter stick welder off the 220v, 30 amp receptacle. This leaves the 120v, 30 amp receptacle available for the plasma cutter.
The plasma cutter output for either input is a 60% duty cycle at 50 amps.
Since both of the plasma cutter's input requirements are 20 amp circuits what is the advantage, if any, to using 220v?
Thanks
Thanks
