- Nov 28, 2016
- 2,392
I have just acquired an old 12 inch Delta Milwaukee disk sander.
It doesn't have a plug on it, and the only thing I can get off the motor tag is where it is stamped '115 8.6' and '230 4.3'...
So... it is a dual-voltage motor... what would that be, about a 1 HP? I'm just guessing...
Also, with my limited electrical knowledge... I'm guessing that it is currently configured for 230v because my ohmmeter shows continuity between the white and black wires, but no continuity between either the white and green or the black and green... the green wire is connected to the motor case...
Would that be correct? Or, how else would I determine how it is configured?
Thanks- Bear
Thanks- Bear
