For the things I make for the Battleship Texas restoration I’ve had the Foundation get 12L14 for most of the items that had to be steel and 4140 when strength or hardness was important. On a fluke I wanted to try 1215 for a complex part. They ordered a 2-1/2” OD piece from McMaster. Only important that it’s a reliable source. Pictures to follow. I have never machined anything as nice as 1215. Not even aluminum or brass alloys have been as nice. The most notable thing is that the cheap Chinese TiN coated inserts leave a beautiful finish at speeds that any lathe can achieve. A surface speed of 300-460 fpm is enough to get beautiful finishes and it responds well to the depths of cut and feed rates that small lathes can achieve as well as working well on bigger machines with aggressive feeds and DOCs. I made several passes at 0.100 DOC and the finish looked the same as lighter passes. It’s very forgiving and pricing is in the 12L14 ballpark. Highly recommended for anyone interested in trying a different steel alloy.
