Finally got my lathe up and running. Thanks so much to Mark Jacob for his build and after sale support. His work is top-notch. What a resource to have around!
The ball oiler on the crosslide screw and the one on the rear of the carriage over the rear ways won't accept any oil. Two on the end of the lead screw, etc. do the same but I see oil coming out of the end so I know it's getting in there. I figure they are either clogged or were already full and won't accept any more. Can anyone provide a bit of input on that?
Also, the change gears. Wow, there's a lot of grease on those. Seems with that much grease then oil makes no difference. It's just going to roll right off that grease. Are you guys removing all that grease or leaving it? It's definitely grease and not cosmoline.
