- Oct 7, 2020
- 2,127
Good looking setup, is that a custom-made chip pan?
Thanks! Yeah my local sheet metal guy made it for me.Good looking setup, is that a custom-made chip pan?
On second thought, maybe I have some additional pictures I can post here.VFD conversion using solid state electronic components.
Nice chip pan... I think that is what i'm gonna shoot for. I ended up taking the lid off my 72" tool chest, so the tray/cavity it created is where my chip pan will go.I recognize that setup... Mine is a 1236.
This chip/drip pan works really nicely but I still get a fair amount that rests on the C-Channel. A minor inconvenience that I was willing to accept given the rigidity of the stand and the ease of leveling the lathe due to this design. :
Very nice looking set up. Putting the electronics in the tool box is a nice approach!
You have room in the box with the VFD to add a braking resistor if you want.
Interesting. Does the PCB have a cpu on it and you plan to add code to it, like a PLC? One day I'll get into PCB design and have my own built, if nothing more than for learning/fun. I just don't have enough based knowledge nor the time to learn the PCB software, like KiCad yet.For my PM1440GT conversion, I recently designed a PCB to replace the hand made point to point wiring that I had put together. I quickly got the boards back from JLCPCB.com , but have yet to solder the components in and check it out.
KiCad is user supported and there is a pretty easy to learn with the getting started tutorial available. It takes one through laying out for a simple switch, resistor, LED circuit. This is all I use to figure it out enough to get started. Then I jumped into doing my own circuit and found that I kept looking back at the tutorial. That worked well. You do of course have to have sufficient knowledge to design the circuits that you want. But this free CAD and the inexpensive pcb service seems to take a lot of the work out of the "hooking it up" process.I just don't have enough based knowledge nor the time to learn the PCB software, like KiCad yet.
In the pictures you posted I did not see the braking resistor. Where did you put it?
I think this is the same 24 volt interface function, but smaller foot print and much cheaper than the PLC. As you noted, I am not for sure why one would want to add a cpu given that the Hitachi VFD is very programmable and provides several intelligent inputs to interface with the control switches.
Looking again at your top enclosure (for the PLC) it appears to have a sufficient foot print to hold all of my conversion. I have not seen behind the control panel on your lathe so do not know how much space is in there. I assume the wires come in from the exchange gear cover area.
I have the same setup when prox sensor is activated.The Jog feature is set up so as to operate even if the proximity sensor is turned on so that one can back away from the proximity trip point.
