- Mar 25, 2015
- 95
O.K. guys, and gals, I've tried every speed/feed combo, every carbide insert I have, every HSS tool I have, I've even put vibration isolation pads between the stand and the floor...nothing seems to work.
Here's what I get...
Please excuse my photography skills.
You can not only SEE the ripples, you can FEEL them.
I 've also tried changing the motor drive belt, I have a link belt on there now. The link belt helped a little(very little)
There doesn't seem to be any unusual vibration problem, a glass of water shows nothing.
Please don't tell me I need a VFD, a lathe of this caliber should not be doing this. However, if a VFD is the only cure then I guess I'll have to install one because I can't be sanding and polishing every part that comes off the lathe.
