The Acra 1440C/1440TE, Kent RML/TRL, and PM-1440TL are all made by Sunmaster which is a high quality Taiwanese lathe manufacturer. You will not be disappointed with these lathes, there are some difference on the models and also the naming is different depending in the importer. Acra sells the 1440C and the 1440TE and you are better off price wise dealing directly with Acra. Kent are a bit more expensive for the same lathe style, Sharp 1340VS and 1440V are a bit too light relative to the Sumasters, as well as the Sumaster lathes have universal gearboxes so no change gears for common metric and imperial threading. The headstocks are wider, if that is a consideration. You can look up the reviews of the different models search 1440C, 1440TE, 1640TE , 1440TL and 1640TL. Acra and Kent versions are available with factory VFD's, others have installed them. Precesion Mathiews sells the 1440TL that quite a few people have, and probably have better post sales support. Acra is probably the least expensive, but the least informative if you do not know what want to buy. I have the 1340ERL, which I like quite a bit, which is a D1-4 chuck mount, if I were buying new I probably would go with the 1440TL/TE with a D1-6 chuck mount and a larger spindle bore.
These lathes like the 1440C are around 2400 lbs and the 1440TL with a solid cast iron base is around 3200 lbs, so factor in how you are going to get it off the flatbed and into your work space. some previous psots to get you started.
My PM 1440TL arrived on Friday and I spent the weekend getting the machine in place, cleaning off all the rust preventative and finishing all the VFD wiring. Took the whole weekend and I put together a video of the process from truck delivery, using a forklift and rollers to get it in place...
www.hobby-machinist.com
I'm going to sell my 1340GT, and I'm looking at the ACRA 1440CVS, same as the 1440C, but with a VFD installed. or the 1440TVS. The TVS is a bigger heavier more robust machine, than the CVS. I can fit the CVS with a little reorganizing, but the TVS is 6" longer, and I still have to make room to...
Earlier this summer I received my new ACRA 1440C lathe. At 2700 pounds there was no way I was wanting to deal with the unloading duties. I ended up having it delivered to a local crane service company. When it arrived they unloaded the machine from the delivery semi and loaded it on their flat...
The machine was ordered mid December of 2017 from ACRA Machinery. The machine took a few weeks to arrive from Taiwan and was shipped to the port of LA, then onto Ranch Cucamonga where ACRA is located. The machine was then delivered to my location via flatbed. The machine sustained a fair amount...
