Way back ('75) when I was an electrician because I thought I was, the old timer I worked for taught me things I never imagined. Like how to bypass a grounded coil in a 2300 volt pump motor. The mold spin motors were compound wound DC motors where we used (shunt) field weakening to intentionally over speed the motor. They weren't that big, maybe 250 HP. But when one failed during operation, an electrician was stationed along side it to keep it running till the end of the production day. Using whatever was necessary, including a fire extinguisher if needed. Swappin a mold motor during operation could block out two or three machines while the crane handled the motor. With down time in the thousands of dollars per minute, it was cheaper to trash a motor than replace it during operation. They were replaced at night and sent to a motor shop that we had been dealing with since the '40s. Leo would rebuild whatever was needed, sometimes the motor leads were marked properly, sometimes not. The brushes were always new, as were the bearings. It essentially was a new motor, just a rough housing. When we changed the motor, the new install was always run for a few minutes without the belts. Not just the rotation, but to verify the motor was actually good. That comment "believe, but verify" struck a chord of memory, which ended up this extended text. Thanks for hearing me through.
