So I spent 3 hours on a metal lathe for the 1st time in my life. I have some wood lathe experience.
This is a big old lathe, sheldon that I suspect to be 50-75 years old. I first put a piece of steel about 1.25 inch round in the chuck.
1st thing i did was grind the parting/cutting tool. Then i cut the end off because it was not square. This went ok. I had the tool slightly below center though and it did not seperate. Then I had to adjust and cut some more. How do you find and place exactly center? How do you ensure it cuts 90 degrees/perpendicular, otherwise you end up with a convex or concave shape.
Then I ground my first bit. Basically a triangular point. I turned down the end of the stock taking about 4 thou at a pass. I tried speed from 300 to 500.
Below is the result. Basically very poor. I must be doing something wrong. Basically looks like fine screw threads. Not smooth. The bit was sharp. I did use a bit of oil as well but that did not change my results. Seemed to be a lot of squeaking type noise even shaking ?????
Any help is greatly appreciated.
