- Dec 11, 2011
- 49
Hi All- so I picked up a Sjogren 5C chuck for my 1236. It did not come with a backplate so I am planning on ordering a plain D1-4 backplate and machining to fit. The check has a recess in the back with a lip that is about .250. Here is my newbie question- I assume that I want to machine the backplate so that it hits the lip and the surface of the recess on the chuck at the same time? Looks fairly simple to do since there is no taper to worry about. My plan would be to make the “spigot” on the backplate a little larger than it needs to be, get the diameter to be a nice fit and then face very gradually to get contact on both surfaces using some Dykem to check. Is that the right way to go about it? Am I missing something really obvious? (Wouldn’t be the first time)
Thanks all-
JP
Thanks all-
JP
