First off, your mill is not the most rigid thing in the world (not an insult - mine isn't either) and running a 2" facemill might be flexing the column, head, spindle, etc.).
Second issue is the tool itself. How much runout (TIR) does it have. It is likely you are only cutting on one insert. Same goes for the axial positioning of the inserts. Are they all pretty close to flat or does one stick out further?
Finally I question how accurately the insert pockets are machined. Are the inserts being held at the correct angle for cutting. This one is very hard if not impossible to measure at home. High end indexable tooling is very expensive and there is a good reason for that.
Oh heavens, no offense taken, I'm well aware that these little mills are very limited in many areas, including rigidity. I got the model with the solid column rather than the one that tilts just to get a little more rigidity.
The R8 mandrel has .0015" runout as does the mill head (meaning the head is actually spot on). I still wonder if that runout is due to how it fits in the spindle.
Yeah, no way for me to evaluate the pockets or even the angles but axially they are all the same.
FWIW, I have that exact same face mill and use those Blue Nano inserts for steel and these inserts for aluminum.
I get a very nice finish when limiting DOC to 0.010" and using 200SFM for steel and 400SFM for aluminum.
My mill is an old Enco BP clone - so maybe that's the difference. Also, I wonder if your material is mild steel. Looks like it might be something harder than 1018?
Thanks for the link, Bill. I got the Blue Nano ones because someone said they were using them with good results on aluminum and that's primarily what I use when I make stuff. I tested with the steel to evaluate the tool/inserts because it wasn't working well on aluminum. The inserts you linked to look much different on the cutting edge, more like what I'm used to on my lathe inserts that work great on aluminum so I'm hopeful these will make the tool give the results I had envisioned, like your picture shows.
Yeah, definitely could be mystery metal but it's the only steel I have. I've milled it with regular 4 flute HSS endmills and had good results. In fact, I made a height gauge base for my little surface plate out of the same hunk of steel and it's very smooth and didn't require much hand work to the bottom surface.
When you take a .010" DoC, is the work piece actually .010" thinner than before the cut? In steel? In aluminum?
Do you lock the Z-axis when you make a pass with the face mill?
Edited for clarification... hopefully.
Good question, Tom. I touched off on the insert that I measured was the "highest" and sure enough, a .010" DOC resulted in the part being .012" thinner. That jives with my measurement of the height of one of the other inserts being about .015" lower.
Lock the Z axis? Shoot, I lock Z, lock Y and even put some pressure on X to limit as much movement there as possible. I even lock the garage door! ;-)
