2"x72" Grinder In A Box Build (gib 2.0)
gt40
Feb 8, 2015
107
I have always wanted a big grinder that can remove large amounts of steel quick. They are really handy for grinding metal to fit for welding, knife making and general fabrication. Years ago I got to play with a Burr king but the price always held me back. Now there are a variety of options of so called "grinder in a box" kits that you generally add a tooling arm or two, motor and wheels and you have a functional machine. I got the kit from Polar bear forge- never dwelt with them before but for $250 bucks, price was right.
The 1/2" thick steel plates arrived in a heavy crate via flat rate. Basically these things are a bunch of 1/2 laser cut steel pieces that assemble into a 2x72 grinder with different attachments and wheels that can be put on it. I got both a flat platen and giant 12" wheel to setup the machine.
Added a 3 hp inverter duty 3 phase motor with a Teco L510 vfd.
Here are a few pics:
side shot with large wheel.jpg boring timing gear.jpg closeup of hub assembly.jpg motor layout.jpg
Here is a short clip grinding 1/4" steel bar:
Thanks for looking...
Chunkier but somewhat similar design to the No Weld Belt Grinder plans available on line from USA Knife Maker that I built. Love it!
I just moved up to Washington state and my mill got destroyed by the shipping company. I am still setting up the new shop so am limited on what I can do right now. I only had to drill a couple of holes with this design and no cutting steel so I just went with a kit vs building my own from scratch...
Very nice!You can really hog off the material really fast.
Interesting design. Is that a lift gate gas spring (like a car) that they use for the tensioner? I wonder where they source that rubber covered wheel from? Looks like the rest is easily made. What would you consider the minimum HP to run this?
R
Yeah, it is a 40 lb gas spring from mcmaster carr. Really smooth...
Hmmm...My brother has a CNC plasma table. Maybe a design of my own???
R
Nice ..things a monster 3hp motor wow! guess that's why ya cant call it a sander can ya
What type of disc belt grade / grit are ya using /
again nice work
