2HL Style B Arbor Support
will.mcray
Dec 13, 2016
164
Looking for a Style B arbor support for a 2HL Universal. Anyone have any leads on one?
Will
I have a couple of arbor supports for a 1H... IIRC, the 1H and 2HL use the same supports... if you can send me the measurements, I'll check and see if they will fit.
From what I have read, the 2HL is identical to a 1H, just with a larger table. I'm not 100% sure about that, though...
-Bear
-Bear
Thanks Bear. I will get measurements tomorrow.
Will
I measured these supports... the support rods are 2.875" on a 4" center to center spread... and about 5.75" from the middle of the rods down to the center of the arbor.
One has a ¾" collet, the other has a 1-⅞" collet. Both will have to be cleaned up and the oil sight glass (plastic) replaced.
-Bear
Bear,
Just confirmed and they are a match. If you want to take to PM to discuss further we can. Let me know what you would like to do if they are excess to your needs.
Will
