- Mar 3, 2013
- 23
I found my lathe is a model 111. I don't know if this will help but I want to cover the bases here.
Does anyone know of a source for a new direction plate (the one with the three idler gears (also are they supposed to be loose?)
Does anyone know of a source for a new main plate (it holds the gears from the spindle down to the quick change input gear).
The last question is on previously mentioned main plate, is there anything between the plate and the headstock where it bolts to the headstock?
Ok really the last question. What holds the back of the headstock down?
Thanks!
Thanks!
