I'm turning a set of stand-offs for a vintage automotive luggage rack out of 303 SS. The stand-offs are 1.25" Diameter turned down to 0.625" diameter. I'm using an AXA-16 carbide holder with Terra Carbide 22-100-047 | TPG321 APC5T 60° Coated Triangle / Indexable Carbide Turning Insert.
![IMG_1733.JPG IMG_1733.JPG](https://www.hobby-machinist.com/data/attachments/237/237825-ca806d583091707efb2aa9e6ffe1d0b0.jpg)
I'm getting decent results, but things seem happiest taking a 0.020" deep cut at the slowest turning and feed speed on my Logan lathe. I've heard that carbide likes to take a deep cut, so I tried deeper and faster cuts, but it just generates a lot of smoke and heat and long stringy chips. At the slower shallower cuts, I alternate between getting C-shaped chips and 2-4 inch strings. Should I just go with what seems to work? I tried steel cutting fluid and the blue water-based soap-like lube (Anchor Lube?)--both stunk to high heaven. Without any lube and cutting slowly with a 0.020" depth of cut things get warm but don't stink.
