- Oct 4, 2016
- 7,047
I did ok taper turning, and taper boring. Drilling was sketchy with just cutting fluid, next time I'll try mist coolant. When it came time to part with my 1/8" inserted carbide blade I had zero runout on the blade going in, and out square to the material, the tool was on height, the gibs not in use were locked down, everything for stiffness was done. 300,400,200 RPM, feed slow, med, and by hand, but it still rattled, I was trying strong mist coolant too. Now the bottom of my beverage container is not flat
