32” Boiler Stack Damper
A three leaf damper, very cool just like we had in our ID fans, only smaller. I want to see the to see the linkage.
That's a helluva hobby project. Most hobbyist build scale model boilers. ;)
Tom
basically the damper is done, a little bit of motor bracket fabrication and the spray bomb job (minion work). With Norm's invaluable help, blades are fitted, all weld together, linkage done, drive arm mounted.
1 - linkage side
2 - drive side
3 - closed
4 - open2CD7350E-C5E5-4B2B-9FB7-2FBDF3659737.jpeg86024C02-1407-4611-837C-2B8B2E38B74D.jpeg3A4B0331-1C7E-4A7B-8A86-876EB6580B05.jpegDB243D31-114E-4A54-8030-31C722DE67CD.jpeg
Really nice job, what fires your boiler? What work does it do? I used to work in a power plant and I heat my house and shop with a coal fired atmospheric water heater.
A 1200 hp boiler boiler, roughly 50 million BTUs (50,000 cuft/hr of natural gas or 360 gph of oil), in a manufacturing facility. This is the first of a possible 3 boilers, over the next 2-3 yrs, if the expansions goes through as planned.
That is so cool! I notice you tacked all the nuts. Smart.
Robert
I finished up the damper this morning, I will still have to make the linkage to operate the damper, but that will be done, at boiler start up. This morning I finished up the drive motor mounting plate, as far as the damper is concerned, all it really needs a minion applied paint job.
the damper is shown with the sample/pattern drive motorAD56C30A-ABDC-4104-A6C9-574D2912AD50.jpeg05261259-30A9-435D-8EB4-2C2D2D05E1B0.jpeg
