[4]
4-40 taps
[3]
[10] Like what you see?
dlane
Sep 27, 2014
3,041
Likes
1,450
#1
I’ll be starting a project requiring two 4-40 taped holes in 6061 aluminum 1.5” deep thru hole , 40total
I tried google search for reduced shank 4-40 taps , didn’t turn up anything that would go that deep , any suggestions ?, coatings?
I have a tapmatic that I was thinking of power taping them.
Also remind me about H2-H3-H5 threads
Thanks
Tinkertoy1941
H-M Platinum Supporter ($50)
May 10, 2012
65
Likes
75
#2
I would suggest a redesign because I think that you can not use the whole 1.500 length of thread.
If the thread has to go through the bottom side open the top side for tap shank clearance.
Need more info
dennys502
Active Member
Mar 15, 2015
114
Likes
116
#3
Do you need threads on both sides of the plate? One side could be drilled larger. H1 is basic pitch to .0005 plus - add .0005 as you go up.
Tinkertoy1941
May 10, 2012
65
Likes
75
#4
Another thought from eBay!
You could grind this pulley tap down to just clear the threads.
FLguy
Jan 11, 2016
256
Likes
140
#7
Ought to work well. That company, I have bought from several times, fast delivery. You could have offered less than their stated price and if with in reason they often accept your bid.
markba633csi
Apr 30, 2015
3,052
Likes
1,579
#8
Be prepared to snap a tap or two trying to tap 4-40 threads that deep. Aluminum is "gummy" and tends to grab. Use plenty of tapping fluid. If you can change the design to make the thread shallower (both width and depth) it would make the job easier
mksj
Jun 12, 2014
1,967
Likes
2,384
#9
You would not use a spiral point tap if this is a blind hole, if a through hole then they would be appropriate. A spiral flute is used on blind holes. You want a short threaded tip, the spiral point will move the chips forward, the spiral flute will pull them back out. Use cutting fluid, if power tapping then make sure the tap alignment to the hole is spot on. If the tapped thread can be a partial, you may be able to drill a slightly larger hole for tapping and do a partial thread, a #43, 2.3 mm or a 3/32 drill are very slightly oversized.
4-40 H2 2 Flute 4" HSS V3 Spiral Flute Bottoming Tap, looks like the it might do threads to 1.5".
https://www.suncoasttools.com/crm/ItemPage.aspx?ItemNumber=800.112040+G9162++YG&VendorNumber=YG1TOOL
This tap is specific for aluminum but the tap depth may be an issue.
https://www.suncoasttools.com/crm/ItemPage.aspx?ItemNumber=800.112040+C0162++YG&VendorNumber=YG1TOOL
The application or design may help others suggest maybe a redesign or alternative solution. I will often tap the bottom of the hole and then use a shoulder which is larger for the top part of the hole. I cut the matching shank and threaded tip to match. The type of aluminum can also make a significant difference, I assume this is 6061?
Glenn Goodlett
Active Member
May 22, 2017
44
Likes
24
#10
I think I'm only good for about 80% on tapping 4-40, so, I would plan on some broken taps and scrapped parts.
Best of luck
dlane
Sep 27, 2014
3,041
Likes
1,450
#11
The hole is taped all the way thru so a 4-40 set screw Locks the top button head screw with a Belleville washer under it,
To keep downward pressure on a rotating aluminum top. I’ve made these before after grinding the tap shank to clear the threads but that tap is wore out. I have a taping fixture or a tapmatic 1a I’m hoping to use.
This is California if you want to see a design pm me.
Thanks for the help, advice, thoughts
Kernbigo
Apr 8, 2012
729
Likes
209
#12
in aluminum use a x-press tap
Kernbigo
Apr 8, 2012
729
Likes
209
#14
Thread forming and x-press are the same thing,that is what they were design for soft material,Besly design that tap when I worked there
Sent from my SM-G900V using Tapatalk
dlane
Sep 27, 2014
3,041
Likes
1,450
#15
Not familiar with those taps , hopefully the ones I ordered will work ok.
pdentrem
Jan 28, 2011
2,006
Likes
492
#16
I see that x-press tap is a company product name. Another piece of info to file away for future use.
[6]
[5] [7]
