- Nov 23, 2014
- 2,606
I'm looking at adding collets to my Grizzly G0709 lathe. Any pitfalls to avoid with a collet chuck vs. a lever style closer? I have a 5-C chuck on a Clausing and a handwheel style 4-C draw bar on a Rockwell. I have no experience with the lever style.
I'm thinking that the lever style would be more accurate than the chuck since it's locating directly off the spindle. The 5-C chuck is pretty easy to take on/off, looks like there's a little work to the lever style.
Another few questions on the lever style. I'm assuming when using a chuck the attachment is removed or at least the draw bar and spindle adapter? Do the collets screw into the draw tube at the spindle adapter? I've seen a collet wrench advertised that has 3 blades for removing the collets. My assumption is the blades go into the slots on the collet, then turn the collet in/out? Obviously a different wrench for square collets.
Thanks for the advice,
Bruce
Bruce
