If you are spending that much for a 5 Gal pale you may consider trying to source Mobil Vacuoline 1409 which I have found works better than the Vactra #2. Another forum member also discussed this with the Mobil Tech and felt it was a better product. I was able to pick it up locally through an oil distributor for around $90 for a 5 gallon pale. I use it on the ways, gearbox and carriage.
Online information:
Mobil Vacuoline is similar to Mobil Vactra#2, but may be better for some way-lube applications, especially for machines with v-ways or box ways. Mobil Vacuoline contains special tackifiers that makes it stay in place better than other way lubes. This oil is extremely sticky, so it is great for those box way or V-way machines. Will stay in place and protect machines where other oils drip or run off.
Mobil Vacuoline 1409 oils are extra high performance lubricants specifically designed to satisfy the requirements of machine tools that use one oil for both hydraulic systems and way lubrication. They are formulated using high quality mineral base oils and a unique additive technology that provides excellent lubricity properties to eliminate stick-slip and chatter of heavily loaded and vertical box ways. They exhibit a high degree of oxidation and thermal stability that increases the service life and helps keep lubricated surfaces clean and free from corrosion or deposits that could detract from finished parts quality and accuracy. Mobil Vacuoline 1400 Series oils provide the optimum balance between these divergent requirements.
These products are the result of an innovative technology to meet the low frictional properties required to assure acceptable production levels of quality parts with minimum downtime in today's high output machine tools. They exhibit the ability to inhibit oxidation and the formation of lacquers and deposits on ways and in hydraulic systems while providing excellent load-carrying performance to control component wear and extend equipment service life.
**Features and Benefits*
The Mobil Vacuoline 1409 oils have been developed to provide an extra margin of machinery protection by satisfying the requirements of hydraulic systems while meeting the stringent demands of the ways. Their outstanding oxidation and thermal stability characteristics improve machine cleanliness and reduce the needs for frequent maintenance services. The dual purpose nature does not compromise either hydraulic system performance or the stick-slip or chatter of ways allowing their effective use in both systems while reducing the potential negative effects of cross contamination of lubricants and water or water-based coolants.
Same as Vacoline Vacouline
