H
Hukshawn
Forum Guest
Register Today
This is what happens when you're a stupid klutzy moron and drop your best, and only hard drill bit on the floor...
...it just doesn't end...
H
Hukshawn
Forum Guest
Register Today
I've been on a bad destructive streak lately. This drill, my good mititoyo digital mic fell off the bench last week, now it's really stiff, that has to go get repaired, I broke a good tap last week too.
The bad three's, it would be really nice if it ended with this drill...
To add insult to precious injury... The wife and I had plans before the boyo came home from daycare... Got called by the daycare an hour prior to coming home, kid has a 102 fever, gotta go get him... Its like the universe knew.
... It just doesn't end!
markba633csi
Apr 30, 2015
4,788
I'm making a guess that maybe you could use some better lighting in your shop?
H
Hukshawn
Forum Guest
Register Today
Hahaha. That’s for sure one thing I’m not lacking.
H
Hukshawn
Forum Guest
Register Today
What I need to do is use my extremely limited time to clean up instead of making this indicator stand....
Dave Smith
H-M Supporter - Silver Member
Mar 10, 2013
1,141
Shawn---all is not ruined totally on the nice broken bit--what I would do is carefully silver solder the bit back together---it will still work ok---you can also turn a larger shank bored out to silver solder the front part of the drill in--it will also work good---just don't throw it away when it can be fixed to drill many more holes---Dave
Ray C
Nov 16, 2012
5,586
Maybe it's time to take a step back and breathe easy for a while. Periods of what you're going through might be a sign of fatigue or loss of concentration. -Happens to all of us...
Several years ago, I was having a klutzy spell just like yours and one sad day, it almost cost me 3 fingers.
Just have a moment of honesty with yourself and think if you need to chill-out for a few days.
Ray
H
Hukshawn
Forum Guest
Register Today
I've been a klutz all my life, but it seems to be a bit worse due to medication lately. Late nights and early mornings. Wife's work schedule has us up at 5:45, and I only ever get time to work after everyone's in bed. Usually that's been fine when we're you at 630. That 45 mins makes a hell of a difference. Its frustrating when life does everything it can to keep you from the hobbies that are supposed to help you relax and unwind.
I desperately need to clean the garage after several rearranges and changes in the garage, but no extra time to do so, extra time is spent working on projects I've been wanting to finish for months.
Just frustrating... Maybe you're right, maybe a step back for a few weeks until the wife's schedule goes back to normal. Especially since my lathe is running again. The parts needed to be made on it had piled up. I want to run it now that it finally runs so well...
Oh well. You're right, better take a break than something bad happen... Sigh...
To add insult to injury, I need glasses (at the ripe old age of 33...) So, adding to my issues, is the issues added over having a hard time seeing.
Ray C
Nov 16, 2012
5,586
Yep, time to chill-out for a while. Sounds like you turned your hobby into an obsession. I get it... good doses of obsession is what drives us and makes things happen but when things start getting weird, it's time fall-back and just cover the basics until your head is screwed back on.
Ray
H
Hukshawn
Forum Guest
Register Today
Bah... If you guys are going to keep giving me good, sound advise, and making good points, I might just have to start listening...
H
Hukshawn
Forum Guest
Register Today
There... I didn't turn any machines on tonight. I started into my therapy/cleaning/organizing. Still a long way to go to recovery.
(Yes, I likey tools hanging infront of me.)
C
cg285
Forum Guest
Register Today
you have way too much time on your hands haha
magicniner
Oct 21, 2017
498
My floor is concrete.
On top of the concrete in machine areas I have flat rubber mats.
On top of the flat rubber mats in all areas I have industrial matting with a hexagonal pattern of through holes designed for standing comfort.
I try not to but if I drop big stuff like lathe chucks there is no damage to floor or equipment.
H
Hukshawn
Forum Guest
Register Today
I like that idea. Has to make cleaning up a chore. My work areas are small enough that the whole open floor space in the garage would be covered in rubber.
The mic and drill bit fell on the floor no where near my working areas. The mic was on the bench near my surface plate where I just had crap piled up, and the drill fell out of my hand coming from the storage shelf.
I've looked at the ergo mats a few times before, there's even thick floor rubber mats often sold at Lowe's, I have one at the side of the house (almost gone) I cut it up and use as cushioning feet under loud machines to dampen vibration.
woodchucker
Nov 25, 2015
1,504
I picked up at a garage sale some 3/8 thick hard rubber interlocking tiles. Not that soft spongy stuff. It's nice for standing on and also if you drop something.
If you can't find that, Tractor supply has the big mats for horses. Real thick and solid . I find the soft stuff hurts my ankles, as they are always working to keep you balanced. The firm stuff is nice . The big mats are a little pricey, but you can't go wrong if you need flooring
AdBlock Detected
I've Disabled AdBlock
