The saga continues…. I was able to get it apart as you suggested. The contacts did not appear stuck but I might have freed them when taking it apart.I would bet that the relay is stuck (contacts welded). I would take a Dremel thin kerf saw and cut the plastic at the seam line on the side with the two male push on terminals (just on the three exposed sides), then delicately pry the part open enough to examine and possibly free the contacts. Once done, take a soldering iron and "weld" it back together.
It's busted, so what do you have to lose.
I did clean them and put the relay back together. After wiring it up and installing the capacitor, I plugged it in and the grinder fired up. The problem now is the capacitor began smoking and got very hot.
Any insight as to the reason for that? The relay is not dropping the capacitor out?
Again, my continued thanks.
Joe
