The spindle is the same size as the 8520, and has an MT2 taper. The only real differences between the two machines AFAIK are the two speed table feed (as seen on the right side of the table) and the 8530 has a more heavily built knee.
Now if it was an 8525 or 8535, then the spindle would be Brown and Sharp taper instead of Morse taper.
This machine appears to be in pretty good shape and is probably well worth the asking price, but only an in person inspection will tell the tale for certain.
