- Oct 14, 2014
- 1,982
I have a beautiful restored 8N tractor. It started running rough last year. Over time, I have replaced EVERYTHING with no success. It will idle fine for a minute, then almost die, then take off again. Can not drive it around, it will stall and die.
I though it was fuel and replaced a rusty gas tank - no help. BTW, I bought a Chinese one an it was slightly larger than original. Had an AWFUL time shoe horning it in. Then installed a new carb - no help.
Decades ago my dad told me its always the ignition. So even though the parts were not that old I put in (over time and many trials) entire new distributor, new coil, new wires, new plugs. Its ALL new still no joy. Timing is spot on 4 degrees BTDC. No dwell meter but point gap is 20 thou. Visually can see plenty of contact and break time.
Double checked compression, its good and does not leak down so the rings and valves are good.
I thought last night, just maybe there's an intake air leak. But I do not know how to check for this. Ideas?
Or any other suggestions. I am about to give up and scrap it out.
